wut? how do I rock endcaps on cars that don't have wings?
anyways...
I'm a van... I'm a van... suck my diiiiiiiiiiiick... I'm a van.
:rant:
I was just saying...
Don't worry :D
I know your cars a wingless.
BMW make vans..?
hey thanks scotty
how many pages is it
the one im looking for should be 150+ pages
its 204 pages and when you scroll to page 4 it says modification notice: GTR model has been introduced, i went through it a bit and it has the whole engine diagram and stuff like that.
yeah?
link me so i can see.... major cbf to look for myself atm :rofl:
i think you should do it right and go defi, it will go well with your car and you wont have these fake defi ones and think damn i wish i waited a bit longer and just got defi's.
I couldn't spend the money on defis.. just a gauge really they are so expensive.. I got cheap mechanical boost gauge and works fine.. hits 10PSI and stops like the car should
thats fair enough, im the opposite when i see something i want ill save up and get it i wont settle for second best, i like to buy the best when i can.
Also is that all that your gtr is running on 10psi?
yeh mate 10-11 psi AFAIK there is a 10 psi restrictor in it which is indicated by a yellow band on one of the 'boost tubes' (not sure what they are actually called >_<)
if i had a 34 gtr then might be a different story with gauges though :D , i would spend money on accessories depending on how much the car is worth in the first place i guess.. my general rule is to spend half the cars value doing it up.. IE if you buy a 10k GTST then spend like 5k max on mods.. or else your just throwing money away just my 2cents.
like my brother got his GTST for like 14k.. and has spent like 14k on it over the last few years on things like rims performance mods etc.. and now his kicking himself he didn't just buy a GTR.
yeh mate 10-11 psi AFAIK there is a 10 psi restrictor in it which is indicated by a yellow band on one of the 'boost tubes' (not sure what they are actually called >_< )
dont need gauges for r34 gtr, i got the screen :O
thats a good rule to go by with mods too.
i didnt think you could ever find a gtr still with the boost restrictor in lol. mine was removed before i got it and it runs 1 bar and sometimes peaks a bit higher which im assuming is normal.
Yeah i probably will go defi
want a boost gauge and oil pressure too
pics when i find my cam cable
well hurry the fuck up then
10psi? lol try 20 in the evo >_<
yeh get some decent pics up, yesterday was good weather !
going to get my mate to take some good ones soon, when we both have free time
also in other news my NACA carbon vent came in today, just too late getting home to get it from post office :D
I think I'm queen of breaking that rule. Over $80,000 on a car that cost me $10,000. But I've had it for a long time.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
