only interested to see what he has to say about his old 32...if the price goes any lower I might have to consider buying it...
f**k... for 7,800 i'd buy it in a second for a drift pig if i didn't have 2 cars already
for track work all it needs is straight pipes, better seat/harness and interior removal
do eeeet
would be nice to see such a great car/deal go to a vic member
didn't he have a 33 gtr? or am i thinking of someone completely different..
or maybe it was that silver 32 gtr that was sitting on its ass?
it is the silver 32 gtst that he had before the 33R
dezz from what i know the car is straight
^^ I thought Abu sold his R32 GTS-T a while back now..?
That's why he bought the R33 GTR, then sold that to buy a house...
RB Ryan has his Silver R32 GTS-T for sale - http://www.skylinesaustralia.com/forums/Vi...nu-t299103.html
do eeeet
I'm tempted... any idea why someone would remove power steering? weight saving is the only thing I could think of, but no idea how much weight would be saved...
my daily is a heap of shit though, so I can't buy a second car that might be a 'pig' in case I ever needed it for daily duties....
hmmmmm
saves weight and has a predictable feel and instant response for drifting :)
when properly setup its very light, I have a manual steering rack in my ksev and its almost as light as the power steering rack in the 33
haha i was in target, buying hoodies lol
haha yeah, looks worse becuase its lowered, car looks good though man.... forgot to check out the exhaust too
you think yours is dirty atm? haha should see mine, mud all flicked up on the side from the tyres from the new rims lol
i work on the other end of the store, mainly in the toy department.
the mud would definately show up badly on a yellow car, but it would just look like you have been out rallying :)
at the crown carpark lastnight i saw a ford BF model painted in midnight purple II.
Don't think I'd be doing much drifting in it... and wouldn't really want a car without power steering for street use, unless it felt like you say..
I'm even tempted by that gtst. Soo cheap, even cheaper without the 33GTRs on it.
How you finding shit-tec dezz?
If I wasn't at school and not working much I'd probably buy it straight away..
Not bad, first week was very slow, but this week was better, little bit more hands on...
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
