you nga's need cars that can break traction in any weather.
Auto is a bit harder I guess.
auto doesnt stop me. its just fun, and easier on the car in the wet
At Crown?
Been there a fair few times. Pretty nice food. You must get the Belgian chocolate desert thingo though. Trust me on this.
+1. this man knows
:down:
took your advice and got me a blitz spec R boost controller btw.. gonna be fun hiding that monster solenoid!
Mine was virtually invisible...Too me a fair bit of effort to see it with a torch and I knew exactly where it was..
anyone know where i can get these songs
DJ Antoine - Underneath (Radio Mix)
M'Black - Heartbreak (M'Black Radio Edit)
happy to buy them
itunes US has them but i cant buy it with my AUS based master card
+1. this man knows
+1 but mines manual now.
didnt stop you leaving kings did it basti that one time.. where um LOL / \/.\ || ... / smoethin like that
:D
you cheating whore, you told me your were getting the gizzmo lol :(
At Crown?
nah in port melbourne, its next to the water, always see ads for it on tv?
..... doesnt matter got booked anyway :P
mmmm just saw a pre-showing of the sorcerer's apprentice....... shit, not even worth the fuel to drive there.... let alone the free tickets
good to know it CAN be done... i've got a couple of ideas... won't discuss them here obviously!
you cheating whore, you told me your were getting the gizzmo lol :D
picked it up for just a tiny bit more than the gizzmo. and it's heaps JDM y0.
sorry brah
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
