Shan:
http://www.otomoto.com.au/kkr/alignment/index.html
MR2 hubcentre is 60.1 and I've been told that these guys are one of the only places that supply them at a reasonable price without custom manufacturing them.
20mm too big?
(Sif edit your post)
Dunno.
haha yeah, realised it was kinda obvious when I read it again... and for some reason thought you'd said 160
Wouldn't be hard parts to machine up really
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
