I need to relocate my cable in teh cef, it wore through a few at first and random shit would happen like headlights go on when i turn the car off or horn when I lock the car.
relocated it a little higher and cable tied the crap out of it, but it's only a matter of time before I hit a hump at speed and the wheel grinds at it.
lol i chained a few cable ties using existing holes in the inner guard to make this spiderweb like thing which pulls the cables up as high as possible.
it's a work of art really. so proud of it.
Like when you go to your little brother to tech him how to be a total bro, and he responds "but you've been passively teaching me my entire life, bro" as your girlfriend walks out of his room. And you then fist-bump in recognition of how proud you are of him.
think i might resign.. this place is too stressful and crazy now days FFFFFFFFFFFFFUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU~
not to mention about 20 people were made redundant recently and emails are going around saying please dont use the colour printer, clearly they are broke
hahaha...your work place is not the only one...i know a lot of poeple who have been shown the door after working years for the place...no respect for the hard working old employees....
people that worked longer then me got the sac.. i guess it comes down to performance and availability.. but its just ridiculous here now you cant even follow up on things without getting told to do something else while your taking 2 minutes to write a email.. so ghey and the management is fail.
anyone got any networking / system admin jobs going at there workplace :D
I got a raise and I hired a new designer for my team. does that count?
also new crackberry should be good. not the bold tho, that's shit. I'd still take the Galaxy S over both... but make sure you get the non AMOLED version, cos the amoled screen is bright but blurry.
No one gets fired from my work. Unless you steal there is nothing they can do lol
that cause all the pissheads keep you in business LOL
ended up getting the Galaxy Ric, charging atm so cant play with it yet :D
edit: how do i know if its the AMOLED version?
Edited by GTS-T_Sedan
i thought 'AMOLED' was the sweet screen that's making everyone furiously fist themselves?
until they stopped and compared it to other screens of the same res and went "WTF is this shit?"
same phone... different screen:
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
