great, now you're gonna be mexican. what happened to 10mm to 15mm?
I dunno.. lol.. I just wanted the rears to be wider than the fronts.
Solution? Epic camber? or flared guards?
20mm shouldn't be a big ask :P
lol tell that to whichever panel beater you get to do that.
you're that high off the ground that no matter what you do, it's gonna look like a bag of dicks. roll your lip and hope for the best.... at least that way you won't cut up your tyres when your springs compress.
i cant wait to finish.. gona go home and slam my face in pillow zzzzzzzzzzzzzzz, and by pillow i mean YOUR mothers boobs
on another note, G27 steering wheels are awesome :P
edit: why are all american modified imports always look so much better then us aussie / bogan spec? should go ship petette over there eh he might get stabbed
well ipretty much have sat at my desk trolling sau,vic,CL google etc.
ran out of things to look up been like this all week =\
same here, its gay cos alot of image hosting sites like imageshack photobucket etc get blocked, as well as facebook and those type of things makes it a bit boring..
no, there's just more of them, so there's a better chance of them doing it well. also their laws are kinda lax and you don't generally get into trouble unless you're packin drugs or driving like a dick.
if you wanna see the amount of dickbaggery by kids with no clue, check out:
http://240sxfamily.com
Facebook.com got blocked here.
Then I started using m.facebook. That got blocked.
Then I used touch.facebook, lite.facebook etc. until they all got blocked.
These days the only one that isn't blocked is pirate Facebook :P en-pi.facebook.com
Only problem is you have to remove the www and replace it with en-pi everytime you go to a new page.
true that makes sense, forgot about there population
I can bypass the proxy server, which means i can get onto what ever site i want but then i'll just get in trouble so not worth it anyways i sometimes just use this method for a picture i really want to see or something not sitting on facebook at work or anything
AGREED!!! works always boring here....days goes very slowly..and then you work 7 days..it becomes a PAIN!!!!!!!!
Why do you work so much man?
I'd rather get less money and have more free time. If you're not out enjoying life then what's the point?
:P
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
