Continue virgin boy.
kill them, kill them all
anyways
guys, im interested in a black S1 R33 GTS
a mate refered me to an add, so i call and the seller says its had a major service, blowing no smoke, not burning oil
mechanically perfect
only thing is, its got some filler in the back left guard.. should i give it a miss? the seller DID just be honest with it and tell me so.... need some experienced input here (and shans flaming lol)
i guess it depends on how desperaste you are and how noticable it is
given its a black car, any imperfection looks horrible
so unless its mirror straight it will look like ass
hmmmm, thing is, i want a black car because almost anything goes with black..
and if its just panel damage, and a small patch. i can live with it for a bit till i get it fixed properly
yeah well it depends on if it will bother you or not
but any black car will show up any panel issues
so if you dont mind that , go for it
but be sure to check the basic mechanical shit etc before forking over cash
people these days too easily fork over their cash without checking stuff etc
specially for a first car you dont want to be suckered into a junker
not bad if you can handle Clooney
His job is too fly all over the country and go to big companies and sack people..Pretty shitty job...But basically he spends his whole life on planes and at airports...goes home about 5 days a year and hates it
Its kinda funny but kinda boring...
"Men That Stare at Goats" was better
Edited by Arthur T3
Thanks man!! Have you got my number?
I don't mind cracked paint. Will just respray them :) No biggie.
i lost it... pm me
lulz
bahahahahahaha
Went and picked up 2 more tyres today and saw these on the Civic at the shop
Come in 15x8 et0 Look crazy!!
they are ripped off SSR longchamp XR4's
the genuine SSR ones come is all sorts of rad offsets and look better
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
