Yea i will, i bottomed out on mountain so thing that was main cause. Its the silicon joiner/clamp that connects from stock piping to the a/m intercooler piping that popped out
fkn lol~ HOW?
stock springs and big bump = bottom out
My car only looks high from the wheelarches, other than that the bodykit is huge, takes 30min to get it on a hoist. Was a challenge to get a rwc cuz guy couldnt get it up, even on a drive on hoist
aww, it's not his fault he didn't find you attractive.
In other news, loving this strong dollar. Spent about 6k in car parts n camera lenses n shit in a week. Better start sellin shit to make up for it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
