thats what nisskid recomended with stock guards and low.. any chance sedans are different?
not sure if different on sedans but, I had scrubbing issues with 17x8 +30 with 235/45 tyres
Had to drop to 225/45's to reduce scrubbing
You are going another inch wider and +20, that will be an interesting fit.
The r33 GTR rims are 17x9 +30. Have a look through the r32 image thread for those rims on the r32. That will give you an idea if there is room for +20
got an invoice for my bodykit from VW US. Including shipping to oz it's $1500 cheaper than what VW AU wanted for the same thing.
Fucking muppets.
Mohsen, fuck you and your fucking pipedreams. Buy a car. Until then I ain't giving you any advice on nothing.
Fucking muppets.
saturday. if nothing goes wrong
kris is right there....
be smart man...
having said that... pat's a fag... those wheels will fit easy... just need to flare more\
why people are afraid of flaring guards on a ~10k car is beyond me... just man up ffs
you wanted aggressive fitment, Rekin runs pretty mild fitment.
the reason why his scrubbed is:
A: he was running a big tyre
B: his guards werent roll enough/right
C: his suspension was too soft
with 17x9 +20 u will be running a 215/45, hard suspension, then u will go at ur guards, just enough to make them fit (rolling and slight pulling in areas). when i talk about stock guards there i mean rolled guards as it's kind of a given if u want any sort of aggressive fitment. u wont need to flare to get a 17x9 +20 under.
17x9 +16 225/45
might have to do something about my spring rates. or do i hope it'll tuck on launch? she squats atleast an inch
getting aggressive fitment on soft suspension is farkin hard, doable, but hard. if u want the aggressive look, then harder springs are ur best bet. but realistically u wanna be going harder dampers as well.
im gonna see how far i get with what i have because i like the ride atm. but i could also do with less roll in corners. its the SK gb spec bilsteins/whiteline fyi.
im running 18x10 +19 all round, 235 and 245. lipped and slightly pulled. no scrubbing cos of how high it is but next thing on the list is low
the circlip adjustment is just the start of ur woes, the biggest problem is they use the standard hats, by having the top spring seat sitting down so low, ur spacing the suspension up, lifting ur car effectively.
u need to turn this:
into this:
be smart man...
seen the car, doing a final check on saturday.
17x9 +16 225/45
awesome, thanks. now to work my ass off again and save for some decent rims/ suspension :blink:
be smart man...
yeah i dunno, i did it on the rear of the evo and it was fine
and thats a low 20 grand car
