Harsh, I am sure you are all old enough to figure out what to do on a Saturday night... :P
A while back I was thinking about doing a SAU Stripper Meetup as an idea for Abu's 21st BDay.
We all cruise to Bar 20 or whatever stripper place of your choice.
:P
so i'm watching tv and aparently the active ingredient in infusion RX is:
"micro encapsulated hydro eronic fusion filling spheres"
lol
http://www.basf.com/group/corporate/en/bra...ERES_HYALURONIC
its a suspension in an acid that gets under the skin then swells up in the presence of water.
haha wonder how it'd react if you washed your face with something of slightly opposite ph, like ammonia.
moral of the story:
find someone who uses infusion RX. wait for them to apply it on their face. then pee on their face. stand back and watch the lulz.
... so go?
:P
Best response ever...
u guys not serious about the cruise to the strippers are you?
Boobs or Hills...
As said, it was just an idea I had for Abu and from memory me, Dezz, AP, Pat, eMsta, Kris + a few more were giving it the shits and giggles about it.
:P
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
