i made them on the lathe, couldnt find anything off the shelf that suited what i wanted. u can buy tein uppers, but they are rose jointed i think, which is pretty much useless on a road car. and im not sure if ur coils are the same OD.
Any chance you got a CAD drawing of them? Might pass them onto the toolmakers at work to make up a set :happy:
I got my rings from speedy wheels
http://www.speedywheels.com.au/
Sent them an email telling them the ID and OD required and it cost me like $20 incl postage for all 4
shan, suck my cock. i would love to see if you act like such a big boy in person
hamish. R32 GTS4 sedan
leigh, you have PM
sorry, shit pics will get more after the roadys done
can I have your airbox? Ill give you an apexi airpod. Induction sound gets the womenz
what the hell does an auto spoiler do? i was lying down looking under the car and my uncle pressed the button.. it came down on my neck LOL
stops you from entering the d-dimension when VTAC kicks in.
just saw on fb that you bought it. congrats.
looks clean
questions:
tur-bro-smart T-piece? so it's had it's boost wound up?
why is the rear bumper hanging off?
is it gunmetal grey or grey or silver?
no compliance plate, so 15 year import, so 1990 or 1989?
ABS, which was only optional on GTSt in those years, and no one got that, so it's a GTS4?
no clutch fluid reservoir, so auto?
fuse on battery so comes with doof doof?
rear brakes are rusted, so it hasn't moved in a while in that pic. defected before?
also, and most importantly:
have you got written exemption for this car?
autospoiler can be lowered when handbrake is engaged. Else it will automatically come down at 80km/h.
Autospoiler aid in creating low pressure in the engine bay to draw in high pressure air (outside air) through the radiator.
thanks, yeah, the previous owners this old dude, he said he put in the t piece.
i noticed the bumper hanging too. looked in the boot and pulled up the carpets and covers, didnt look like there was any damage.
also looked under it. saw the front drive shafts so i take its an AWD
its TG0 colour( looks like a bluish grey silver)
its a personal import.
it was sitting for 2 months before the previous owner decided to get it back on the road
and no, no written exemption :happy:
nevermind, found the car.
http://www.carsales.com.au/all-cars/privat....aspx?R=9281023
it was in dandy too... ffs, you coulda asked me to come check out the car with you. I live like 5 mins from there.
Explains the rusted brakes from sitting on the yard.
If it's that strip of dealerships I'm thinking of (next to Hertz) I think I know the guy who sold you the car too.
shan you feeling alright? your being awfully co-operative
he brought it to me because i didnt have a lift to dandy.
I may be a total cunt to you (cos seriously, nothing gives me more pleasure) but I wouldn't wanna see you with a bad car or get ripped off. Consider it tough love.
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
