Mohsen.. congrats. But shut up now lol.
To do list:
Get money back from faulty boost controller
Buy functional boost controller
Remove stupid narrow bit of front pipe and replace with 3" straight pipe
Tune
Block off BOV
Eat sandwiches
Very nice.
What was your reason for the hats? Looks to me like you can achieve a lower setup without dropping down the circlip? This would mean more suspension travel without hitting the bump stops?
yeh basically just dropping the lower seat lower (in my case winding it down), would have got me lower, but i would have ridden on the bump stops and given me no travel, this way ive done it has lowered the car, but has actually given me back my stroke, and complete control over it simply by adding in spacers to drop the bump stop to a point where it is bottoming out.
i actually dropped my car a while ago and after a certain point, winding down my coilovers didnt actually lower the car anymore, because the car was sitting on bump stops, not the coils lol. wasnt THAT low either.
yeah, the control unit turns on and seems ok.. but had it on 100 gain and 100 duty and didn't do a thing lol. double checked with Ruffels' control unit with my solenoid etc and it worked perfectly. chasing the guy up through paypal... so annoying! and i was only half serious about the BOV :)
Leigh: Bitches ain't shit
whats with the womens and mind games? one night they like you the next it feels completely different, so confused right now.
yell at them
then throw things at them
thanks and nerrr :)
leigh fk that. last girl i had a proper crack at gave me signs for about a week or two and then completely turned around. now she's standoffish and told a 'mate' of mine "i think he likes me but im not sure what i feel". 'mate' cos flamin mongrel has been trying to hook in w her behind my back
solution, fk them both off, basti's happy, world still revolves
its beyond me how a mate would do that to a mate :)
anywayy
That's what happens when u meet womenz or the interwebz! Worked out for jezza tho so dunno lol
Eh? :) Aren't you the one that met Cass through SAU/SEI? You can almost thank me, coz I organised the cruise where you first met in person :wub:
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
