engines are horizontally opposite thats all
they actually arnt that hard to work on.... take off a few parts and everything is easy to get to
in saying that the 4g63 is one hell of an engine :)
So much easier to work on an EVO engine then a RB cuz there is so much room.
+ Your oil filter is easier to get to.
But having said that, if you know what your doing, you can get around it in the RB.
the filter is easy to get to whaddya talkin bout?
dont tighten it to the shithouse in the first place and you wont have any issues, should be hand tight, but you all know this already.
rally races < every other type of race (inc greyhounds)
/thread
one of these days you'll come to the realisation that your opinion counts for shit fuck all due to excessive faggotry and profuse n00bletry.
A lot of people say rally is the most skill demanding motorsport and I have to agree, probably F1 about equal as well but at least the tracks they race on stay the same just there reaction times are f*kn sweet.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
