I'd say F1 would require the most skill.
Take all the skills needed to drive, then reduce the reaction time available by tenfold.
True that, but the F1 car are now slowly going back to driver skill. Few years ago it was all electorincally assisted? mostly car not driver.
More likely to die in rally. Also much more interesting to watch rally. See any pikes peak hillclimb vid and tell me you aren't impressed. Skill level is probably on a par, just in different areas.
when was the last time you saw an F1 car with a rollcage?
F1 car = nuts hangin so low that they're literally 5cm off the ground.
I got my rally day in november! Driving a Evo 7 round a rally track. Hope they got insurance! hahaha
Is that the one out near ballarat? My mate went to that one and they gave him a Magna VRX "Evo". He asked for a refund and they refused.
Say whaa, nuh this one is in werribee
And says your choice or a Lancer Evolution 7 or a Subaru WRX
haha magna vrx as an evo
nice work
i went in an evo 7 around debortoli with scott pedder
that was pretty sweet, fair driving he can do
brake and accelerate at the same time
When was the last time you saw a rally car with a CF saftey monocoque shell?
Rally= nuts so big they be sideways at 80-100k's an hr 20cm from a massive drop off a mountain. :)
Dunno about last time, but I can tell you the first time... 1987. Lancia entered 2 CF shelled rally cars.
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
