billy get an ipad.
Lol im not that stupid.
There is no way i'd buy a HP, have also had issues with them in the past. At the moment im using a lenovo laptop and before that a Thinkpad, they are great so I was considering another lenovo.
Im looking at an i5 or i7, I will end up using CS5 and playing starcraft 2 on it so it needs to be decent.
So what'll it be, ASUS, Acer or Lenovo?
ahh man your fkn live is over if you start playin starcraft 2.. shit is addictive baddddddddddddddddddddddddddddddd
what he meant to say is, "your gonna game with me, clutch and r31nismoid yo, P.S im a queer"
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
