Going by website they only go up to 9.5 like I have with the advans now though? 9.5 is preferable for me if only bc I can use the rubber I already have again. Unless u know where to get dirt cheap tyres too? Lol I might give him a call
cas, has vicroads given you a cheque yet? you're gettin all mohsen on us now. horse before cart n all that. give em a quote for the replacement of the wheel that was damaged only, and IF they pay you (which I doubt) then start looking for wheels. No point getting yourself pointlessly into more debt.
reason I ask shan is because I've looked everywhere to quote a replacement and can't find an 18" in any width for the life of me ergo I need new wheels as a necessity no matter who pays for them. I'm trying to get all the info I can get prior to speaking to vicroads so they can't catch me unawares and pull dodgy shit on me. Being informed is not being mohsen. I thought ud argue it's quite the opposite :P
lol jk mohsen
yeah but you have a better chance of a payout if you gave them a quote for one hypothetical wheel replacement rather than a higher quote for a full set of replacement wheels. I don't think Vicroads will care if you can get them or not.
Having dealt with insurance companies when putting together quotes for the workshop, it's not wise to overquote as they might go into full out deny deny deny mode.
Just sayin.
Trust me i wish i could quote them less than I'm having to do at this stage. Even if they have to only pay for one of the four I'm going to have to buy I'm at wits end here- how can I quote a price on a wheel I can't buy because nobody makes or has them anymore? I can't. But if I want any kind of assistance I need to be able to bring some figures to the table per se. For the record import monster just quoted me 1850 for four cr kais new. not bad comparitively with other wheels. I've emailed streeter this morning. Import monster also have said pretty much no effing way am I gonna find an advan anytime soon.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
