btw cas...
http://page7.auctions.yahoo.co.jp/jp/auction/g91619685
17x9.5" 114.3 PCD.
$260 buy it now for 3 + shipping costs + agent costs + international freight.
use two of em and have one as a spare. or get streeter to just chuck one out and send 2 to save on shipping.
problem is that that's too small. Can find 15s, 16s n 17s but no 18s to suit gtr. No 18s at all actually
How much do you reckon this 'car' would go for thesedays?
limited edition convertible model AE86. NOTHING to do... just get in and sliiiide.
so umm shan i mught need your thread tap things. got the centercaps drilled off, but the threaded bits of the screws are still in there
why the fuck did you drill the caps off? that just makes it harder to pull out.
oh, I thought you ran 17's on yours. my bad.
all good man thanks for looking :) did u know the guy who bought the damn things ran spacers underneath. Only 5ml tho. I had no idea lol
reply to my facey msg Nick! :) no love
sorry dude been absolutely swamped with work this week, and busy all weekend
When do you need it done by? maybe i can do it on wednesday next week during the night or next weekend?
hamish - thanks for the tip with streeter :) import monster quoted 1850 which i was already impressed by - streeter just got back to me as below:
Work CR Kais
Bronze
5x114.3
18 9.5
22730yen each
If shipped by Sea Post (shipping time 6-9 weeks)
Rough costs on that would be something like this…
Cost of item ¥90,920
Ship item to me ¥0
Bank fee to pay seller ¥630
My commission ¥7,000
Shipping to Aus, Europe or U.S. via Sea assuming 13 kg x4 ¥31,200
* (I could be off with the weight but what ever it costs to send Ill
pass on to you)
ROUGH TOTAL in JPY: ¥129,750
*If not in Aus or you would prefer to use PAYPAL: plus 4% paypal fees ¥134,940
ROUGH TOTAL in AUD: $1,674
*depending on exchange rate. current rate is 80.8
pretty happy with that but 9 weeks is a bit worrying. means i need to find loaners in interim. assuming i get them.
...i want to.
niggaroj, come over saturday, I'll be working on the ceffy.
I use laurence (jesse's old housemate) and also streeter when L's not available and they're ace. never had any dramas. it's not 9 weeks. 9 weeks is worst case. I get my stuff in a month usually.
thats pretty comforting, thanks :)
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
