aaron balaclava and jesse streeter are both equally good options. I prefer jesse, but if it came to freighting large items like bodykits etc I'd go with aaron cocolover.
limited edition convertible model AE86. NOTHING to do... just get in and sliiiide.
lol
erm, what local sport teams?
simpsons quote man... :D
anyone have any idea where can I get thread apadtor for gearknobs?
12mm to 10mm
i tried when i busted mine.... couldn't find one ANYWHERE! best bet is to get someone to drill tap a 12mm bolt
actually screw that.... you'll be able to fine one easy...
toyota's have 12mm threads, so get on AE86DC and ask around for someone that bought a dildo knob that doesn't require the adapter anymore
euro car drivers are cocks.. like the audi a4 driver who was up my ass this morning, trying to get me to do something stupid.. should of seen how this flamin mongrel was taking corners after i let him pass. thinks he's la bomba or something
lol... what rims you looking at mang?
rims? just loving the snot out of the fact that all I have to do change all the bushings and bearings on my golf is buy a "refresh kit" for $150 and off I go, all I have to do is put my model in and it gets everythign I need, packages it up and sends it. Or if I want a new control arm, 5 different companies make em from $29 to $89... none of this fishing for secondhand shit, and it's all quality parts too. everything is plug n play. bodykits are plastic not fibreglass... etc etc.
audi a4/bmw 3series with 2jz :D would be saweeeeeeet.
lol
im liking rota grids atm
or maybe even the LMGT4 replicas.. but before all that. gotta worrrrrkkkkkkkk
edit: need the money elsewhere, on more important shit atm
also: call me crazy but i dont think they would suit the 32
Edited by Mohsen
Jizzy, fk offfff kent. U know u want the mohsen.... :D
really? did you just refer to buttfucking a dude as "the mohsen"
Seems like he did
lol that's mad homo.
Lol no, I refered to raining man jellllly
Oh wow im a idiot,
Was on the Monash coming come just now doing like 100-110 or wat evs.. anyway my car was like completely fogged up / dark tink so couldn't see too much anyway for some reason I thought there was a golf GTI coming up next to me and egging me on.. half asleep i chucked it down a gear and gave it a little squirt (nothing to major) then this 'golf' all of a sudden flashed cop lights (was one of those 4wd police cars) next to me for a split second and I'm like WTFLOL then he turns off the freeway exit.
Major wtf moment, didn't pull me over or anything I think he must of just been a young guy wanting to see some hecktik dosing bro. LOL
Remind me not to do that again, scared the sheeeit out of me.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
    • Welcome mate. Any pics? Even with a DE I'd be well happy if I had that as a 1st car.
