mm yeah all mine are intact miraculously, nearly fkn broke one yesterday dusting them, they dont like to be moved around much ;)
mohsen : professors look good on just about anything.
don't get cheap wheels, you're only cheating yourself. If you can't afford decent ones, keep the stockies on
Edited by bozodos
car is officially EPA cleared as of 11am today! Thank f**k.
All he did was open the bonnet, see that there were red injectors in there. Took a photo of the injectors, engine bay, front and rear of car and asked for $38 retest fee -___-
Should have just painted my ones red instead of swapping. Least we know the extent of checking. No injector duty cycle measurement etc
Car is bog stock now ;)
So you passed emissions but had to change your injectors anyway?
yup lol
I went in with nistune and a fuelmap which made the larger injectors pass emissions. Although he didnt like the colour of the purple injectors and said they had to be red ~_~
That just seems so... retarded...
The whole point is emissions... if you meet them what does it matter.. stupid victoria
haha yeah. In the EPA guidelines, larger injectors are illegal regardless if you can make them meet emission test at idle. The other option is to engineer the injectors but would need to involve a full ADR emission test which costs $1600 for the test. (this would involve emissions beyond a simple idle test like the EPA inspections do.)
Not worth the trouble, easier to just swap them over.
keeping the s15 stockers on it till i can get something good.
like these
seriously though
rotas..
also, loving my super glue repair job. looks like its untouched
some flamin mongrel almost hit me last night..
was on kingsway, at the edgars road intersection.
light goes green, i go straight (my way the whole way) and then some stupid flamin mongrel in a VE commo comes out of nowhere on my right and almost hits me...
what do you do to remove the speed limiter? is it just removing a fuse or something or is it built in the ecu? just curious for when i get into some trackdays in the future.
edit: on second thoughts by then ill have an aftermarket ecu anyway so it doesnt matter.
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
