Yep, a cock juggling thunderflamin mongrel. Then I told him to look up the definition. He spent the next 10 minutes on urban dictionary :)
Edited by jezza boii
Well I went the high road and told them... they said good on me for saying something. All good, although I'm pretty excellent already so I don't think this made any difference to my Brownies Points. It's a bit like in Zelda when you are full powered but still can't resist catching all of those little hearts :) mmmmm hearts.
Alex, I work for CGU Insurance :worship:
you were sounding cool and shit up until this point.
Good point. I like to mix it up a bit though, try new beers etc.
A slab of Coronas will never go wasted though :P
EDIT: Ric beat me to it :down:
the mrs and i drink usually
~2 slabs a week (usually 1 corona and 1 hieneken imports)
a different beer from work as my knockoff 5/7 nights
a case of wine every 2 weeks
a bottle of belvedere a fortnight
bottle of cognag/armagnac a month (mrs don't touch this)
so i get plenty of "variety" :down:
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
