Whats happenin Jamie, Havent seen you in a while.
It was about 2 weeks ago at Garage Cafe :)
Just working and taking it easy.
Hey you still looking around for ppl to fix your rear bushings or whatever needs done?
My friend owns JAK Motorsport (Former as Drift Line)
Jack from Chasers works there now and he can probably quote you up on a price to fix.
Yeah gotta catch up soon.
yeah Oettinger 500ml cans are about all I drink these days, $42 for a slab, can't go wrong! (esp when CUB slabs are $48 fkn dollars!) $35 for slabs of most German beers at the Liquorlands / Woolies around here too, its great!
Boags is vile man, forced myself to drink a slab of it last cup day, shitful.
hame thats a fair intake of alcohol mate. might wanna watch that
/medical brain
everyone loves corona yes, but you gotta use lime. lemon is for wimmin. others that are on my regular list are asahi, beez neez, little creatures pale and golden, james squire, becks, bluetongue (white rabbit is pretty similar to this too), heineken, boags. guiness goes down a treat too
i try to drink something new as often as possible. dont drink spirits as much nowadays but partial to a bit of CC and Hennessy. can not even smell vodka after a certain incident a couple of years back lol
on tap at Shou Sumiyaki was the best :)
*Free
fucken tightarsed maso's :)
the mechanic from driftline Monty works at chasers now.
divided. I should go to Jak cos well, it's the old stomping ground, but then Monty knows his shit, and Kamikaze's on my side of town. decisions. decisions.
boags is ok in light form, heavy is horrible
cascade is good, light or heavy
vb horrible period.
carlton draught, not bad, a light form would be goooood
carlton cold, good as a heavy
tooyeys (however its spelt) extra dry = my fav heavy beer
tooyeys one with the lime, pretty farken good to for a heavy
dont like corona
tooyeys red, good for a cheap heavy
Mate ofmineis dropping a tt engine into his na poopra thru JAK. I was recommendind driftline to him recently. No idea that they're the same joint now.
Where's kamikaze?
Where's kamikaze?
lol yeah sold up the business, jak still pays rent tho :P they also paid for the shittonne of spare parts we had in there.
Where's kamikaze?
Is your mates Supra that, off colour Bronze / Titanium Grey 1 with the body kit?
It was about 2 weeks ago at Garage Cafe :P
Hmm yeh still need new subframe bushes but i've been saving to get the corona on the road which should be happenin this/next week if everything goes well :rofl: then I'll put the GTR away for a while till i get more money to fix it up.
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
