It makes me a bit sad that you have an R32 to molest mohsen
we'll just publicly shame and humiliate him until HESDOINITRIGHT. So in fact, Mohsen didn't buy an R32, VIC wasteland just did.
pity it's auto. although, 11ty billion times easier to swap to stagea RB25 tho.
Anyone know where to get SSR centre caps? Or at least something that will fit?
the reason no one runs 'em is that they look SHIT
i had some on my rims, gave 'em to thuy so some douchebag could buy 'em for a douchebag price and look like a douche
if you want the centres to look better, just get hub rings :D and dpray the centres of your hub's with a black can
is what i did
sure is funkeh, I also have the original receipt from SSS automotive which clearly says motor and gearbox (was thinking it had to be the original GTS-4 box for a while)
might have to check your car out to see what needs to be done for a conversion. depending on if I decide to keep the GTR or flog it for mad profits I might swap in RB25/30 into GTS4.
ha me neither, but its his car.
this is my kinda supra
Yeah man!
That's it.
I would like a Supra with the TRD Aero kit, slammed and tight fitment and that be it.
I don't mind the wide body 1's too but has to be done right.
This is win!
the only decent poopra on earth:
all other poopras are instafails.
Bad as!
I've always liked this Supra. Used to see it on the highway all the time. Would look nice if it was alot lower though..
That looks nice.
That was the 1 I saw at RE Customs Dyno Night.
Supra's need aggressive style wheels or anything with deep lip.
Hows the R32 GTR coming on?
engine's out for some lulz at the workshop. should be ready in another month or so. told em to take their time, no rush. gotta try and finish the golf off first.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
