fkn barbs
yet another reason to hate barbs...
It's perfectly safe. Every mechanic has told me that. They couldn't even tell that the chassis was bent. It was the old owner that told me that.
dood... that's a fkn dog act.... i'd headin over with a baseball bat
my commodores chassi is bent and you cant tell if it is...car runs pretty straight....lol...
of course you cant tell it's a commo. it probably came out of the factory bent and you crashed and straightened it
:D 1st gutter = straighten it up but the 2nd gutter = bending it more than usual... :) ..been through 2 diffs in that car...give it the beatn of its life time...always shift after four thousand revs... :) (redlines starts just after 5)
friday.is.goods
AGREE!!! DAY TO TAKE MY GTR OUT!!!!
:) sadly the weather doesnt look good for a good nit cruise...
if it doesn't crab and can be negated with suspension alignment, then it's fine to drive. did the owner tell you what else he hulk smashed when he bent the chassis?
If you are gonna fix the bent chassis it's a big job. I'd recommend a ditch and run if it's bad enough that you have to.
if you've munted a car enough to bend the chassis, then the only thing the control arms etc are gonna be good for is as a door stop. You kinda have to replace em, he wasn't doing any favours.
maybe get adjustable arms, makes it easier to offset any misalignments in the chassis compared to static factory replacements.
He said he replaced everything on the left/rear. Tie rod, control arms, etc.
sounds like the result of some epic snap oversteer.
Yeah he was drifting in the wet lol. Who the hell drifts an MR2?!
Where do I get adjustable arms?
I just my car up for sale so want to find out this shit asap lol.
Edited by jezza boii
ok relax, do the following in this order:
1. find out if the alignment can be accounted for using your existing suspension
2. if not find out how much it needs to be adjusted by and what aftermarket arms can give you this amount of adjustment
3. if yes, buy aftermarket arms, fit, drive, enjoy
4. if no, sell car
ok? don't try and do everything all at once. work through the problem.
well you, and the previous owner have both driven this car with the problem just fine so far, so driving it a bit longer just the way it is isn't gonna hurt. it may wear out your tyres unevenly and make it slighly unpredictable to steer on the limit, but it shouldn't matter if you're driving normally.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
