I think the problem is cos he's running an atmo BOV. recirc it and it'll fix it right up.
or, its cos his strut brace is bent, if it was straight im sure there would have been much less damage to the front end in the accident
your MR2 is a fucking daily. it's not some high performance car that's undriveable on a daily basis with a twin/triple plate brass button clutch that makes it a bitch to drive in traffic like the rest of ours.
your MR2 is a f**king daily. it's not some high performance car that's undriveable on a daily basis with a twin/triple plate brass button clutch that makes it a bitch to drive in traffic like the rest of ours.
True, but I'd rather leave an Excel in the 40 degree direct sunlight for the whole of summer. Would save heaps on petrol too :) And my clutch/gearbox make daily driving hell.
man I'd hate to see how much you'd bitch and whine if you had a real performance car with proper go fast mods.
you bought the mr2 to drive it not just look at it, my gtr is my daily and i love it, the reason i bought it is so i can drive it, if i got a daily my gtr would never get driven because i drink most weekends lol.
i rather drive than drink...lol...so i got a daily with my gtr...lol...get a commo jezzi...much better than the stupid excel...and if you and find it in manual like what i have, its a bonus...hehehe
Harsh boy. Race sim tonight?
prob not tonight bro...got work at 5 tommorrow morning and already going to the movie night thing at doncaster with the other SAU boyz....thats going to get late enough...ill be driving past it on my way back home, ill call you then and might just pop in to say hi...k :)
Hmm... I like that, but I saw Mohsen's R32 pics and another R32 4 door last week... It's a hard choice :)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
