bbs lmp 071 forged 17x8 17x9 dont no if those one's on that beema a real or not they look it....
nice rims dude they're exactly like the ones i had on my car when i got it.
funky can spin it any way he wants, the ones on the m3 are genuine LM's. the end.
BN/Uras/Whetverthef**k on sedan... done right:
I have 32 sedan, have AVS Model T5 but it's minus coilover, BN kit + healthy motor.
Hmm.....
Anyone have RB20 to sell it to me?
midnight purple II i think it is on that BNR34 from the macedon cruise with the extra black lip and black TE37s is pure porn
nice work whoever owns that car, im sure its worth a few $
http://www.skylinesaustralia.com/forums/Mt....html&st=40
