someone's gotta do it...
it's more about the positives of helping that the negatives of failed train surfing :P
Just wondering, what was the reason for you to become a paramedic if you don't mind me asking?
japwarehouse arranged it so i dunno who did it to be honest but yeh sorted it all out no dramas, its a pain in teh ass with low cars.
ask kriss think he goes to tyre factory sunshine apparntly they arent bad but wait WITH your car.
where can i get some nice and shiney twin tip "blast pipes" or whatever they're called? thinking of attaching one to some s/steel 3" pipe all the way to front pipe. deleting cat/mufflers hmm vroom vroom
I would actually fkn love that job :P Touching dead people doesn't bother me at all.
my brother's mate is a paramedic. the pics he's shown me... i seriously dont know how people can do that job.
Had to do all that application bullshit and go for an interview when I got offered Architecture at RMIT. Then I changed my mind and decided to be a town planner. Four years of study and three years of work in the industry and now I paint houses for a living. Fml. Should have been an architect.
R-Spec: Exhaust Technologies in Adelaide are the only place I can think of that makes them, feel free to add any in Melbourne if you know lol. I thought about this when I had my straight pipe, but then got an EPA shafting lolz
thats shit sif none in melb?
you'll get done either way so meh might aswell make it worthwhile lol
What year? I applied for their architecture course and had to do that wierd test thingy in Swanston St in late 2001. Didn't get in, so ever since, I've been a sparky :P
In a way I kind of want to do a bit of tertiary study for some better coinage, but no idea what, and most things probably wouldn't pay as well as what I am doing now. I'll possibly just teach myself some PLC programming, as there is some big bucks to be had in that.
A few, at funerals and shit :P Would be even easier if I didn't know the person. I'm just not really phased by death etc. like normal people are. It's just a fact of life in my eyes.
In other news... FUUUUUUUU my bodykit got damaged in storage. Better hope fiberglassing can fix that shit.
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
