A few, at funerals and shit :P Would be even easier if I didn't know the person. I'm just not really phased by death etc. like normal people are. It's just a fact of life in my eyes.
In other news... FUUUUUUUU my bodykit got damaged in storage. Better hope fiberglassing can fix that shit.
im a stonemason and yet to touch a dead body so far, you got some problems dude :D
although death doesnt phase me either, just puts life into perspective more
What year? I applied for their architecture course and had to do that wierd test thingy in Swanston St in late 2001. Didn't get in, so ever since, I've been a sparky :P
In a way I kind of want to do a bit of tertiary study for some better coinage, but no idea what, and most things probably wouldn't pay as well as what I am doing now. I'll possibly just teach myself some PLC programming, as there is some big bucks to be had in that.
2006 for me. I never showed up for the interview lol. Aaah well, one day i'll figure out what I want to do with my life lol.
how many dead bodies have you touched?
icwatyoudidthere
LOL
ignitor arrived, put it in. some improvement overall but still dead in cylinder 1
gonna get my loom checked out tomorrow, if its fine. ill move onto injectors
Nice one, I had a Trust DD back when I had a skyline
hmm thats quite sexy. would yo get away with driving that on the street?
and jez im just asking because seeing someone laid out in a casket barely counts, cos they are cleaned and perfumed and have make up etc on to make em look nice for the family. hamish is gonna have to put up with worse than that. good on ya hamish, there can never be too many paramedics. is mez for or against you getting into the health industry? curious to find out where she stands lol
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
