Firesport, when I looked at it the symptoms were telling that turbo is blown, when I bought it home the symptoms are pointing at blown headgasket along with cream on oil cap...
Fun times ahead...
Already considering ebay it and see how I go...
ah nice. Is it really that hard to find a rb20? Thought there would be millions of them, as who would want them?
f**kin love this guy
u got an RB20 injector?
i do, but its dirty as
Geez who's r32 here doesn't break. Hard to come by these days :D
mine didnt :)
but i spent enough on it and then sold it :O
its an older car, what do you expect?
What I find amusing is that I cant seem to find any s1 burgandy r33's anymore. Couple years back, there were thousands of them. Now they all have disappeared. wtf happened to them
actually depends how its been taken care of mostly
who sells 3" flexi pipe by the meter?
bunnings is epic fail
wtf for?
The r32 is at sometimes 6-9yrs older than a r33. Which is a car that has taken its learnings from the r32 and made changes.
So of course, the r33 will be more reliable than a r32 as it is newer and any bugs/weak points have been addressed.
Its the reason why r34's look so much better cause they realised their mistake with the r33 styling and went back to a similar r32 design /troll :D
Without getting one for reasonable price, just had someone trying to sell me one for same price as 25det...
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
