hahahah...try working 7 days a week and you only get one night for free time/going out time...when its that case you only look forward for that one night every day of the week...
when the day comes and you cant go out..trust me bro its depressing...another 7 days of straight work before that night to come now...:D
since you mentioned car troubles, if its the freakn commodore that is giving me the shits...falling apart...damb commodores...
I don't know how people can work 7 days a week. What's the point in living if you're not gonna enjoy it? :D I'd rather be a poor kent and work 5 days a week than be wealthy with no life.
only 3 more months for this to go....its only coz i am doing my work experience from uni...and want to keep my part time job for after i finish...so therefore i am having to work 7 days...
hehehe...jezzi i still have a life but now limited to that one night (fri nit) a week...so i do get upset when something comes up and i can go out...
STRIPPA!!!! lol
Nah doing my work experience as a biomedical engineer in monash clayton and work weekends in safeway..(slaveway)..lol...
going back to uni next year so had to keep this job and had to work it throughout the year...cant complian...plenty of extra cash for the gtr and the houses... :D
STRIPPA!!!! lol
Doing the night shift at Slaveway huh... :P
Next time you come to a SAU meet, bring some decent food from Safeway and we'd eat it :devil:
nah man...work in slaveway durign the day...sat and sun all day usually...but get occasional late start on sats...so therefore fri nits is only nit i get to go out and be able to sleep in.. :P
I don't know how people can work 7 days a week. What's the point in living if you're not gonna enjoy it? :P I'd rather be a poor kent and work 5 days a week than be wealthy with no life.
I work 2 days a week... quit sooking about being poor! lol
How could you even afford to buy a car working 2 days a week? :P Back when I was working 4 days a week it took me a whole year to save for an NA MR2!
Btw, fully tempted to join this elite 300kw club :devil: I wanna be like Rik, Kris and Hamish.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
