I just had a spider attack then actually... Huntsman vs size 14 Nike dunks... Guess who won
Phil Knight?
there everywhere in my garage. luckily house got spider bombed a while ago so all im finding is a fk load of them upside down alive praying for a miracle. luckily that miracle is there when they get put inside my Silvia exhaust :P
i got a little trap spider that lives somewhere in my car. Tiny but they've got that little spider syndrome, where they spin like this big fuckoff thick web to catch shit on. nga's spun a web across my driver side passenger door and rear fender and also started one last night on my side mirror.
you know hamish problem is its one down one to go..
i killed one in the office last week big motherf*cker used half a can on him.. walk in yesterday BAM on the wall was his brother even bigger motherf*cker.
yehh. its 2 - 0
I used to have a spider that lived in the side mirror of my old corolla. He was there the entire time I had the car. I would spray the mirror with water every now and again, and surely enough the next day a spider web would reappear. I eventually gave up and just let the spider live there. I mean, who am I to destroy his place of residence? I even affectionately named him, Terence.
Rex has poo wheels! There are numerous 2dr wrx's in my area.... one is even sporting altezza tail light! haha
Take that back!
Hmmm, quiet night in here.
Question for wasteland:
Federal 595 EVO or Kumho KU31 for my next set of street tyres?
Hero's man :P
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
