the dude that owns JZX100 works in one of the places near my shop
pretty much watched that thing go from daily to part time tracker to fully stripped screamer, straight pipes and all.
is tough
So any phone geeks (Shan, I'm looking at you) able to help me?
Been offered a HTC Desire HD to replace my iPhone 3G... yay or nay? I'm a bit over the iPhone, so wouldn't mind trying an Android or W7 phone, but yeah...need some more smarterer advice.
only tards buy Verossas. Chaser/Cresta/Mark II is where it's at.
besides, verossas aren't allowed for import on account of them looking like a dugong. True story.
http://www.j-spec.com.au/wiki/Toyota/Chase..._only%29/id-514
then again, most skyline drivers cling to the 90's like it wasn't 20 years ago.
The Rise, lay it on me..
well not certain but i'd think it will be similar to most areas ie. pretty sh*t at peak times.
unless they have upgraded the exchange but i doubt it.. most ppl go for wireless
Shan, what's a good amount of negative camber for my fronts? Just wanna get some figures so I can tell the wheel alignment guys when I finally get around to getting it done :D
none. you have a snap heavy mid engined RWD car. any negative camber on the front and not the rear will make it even more snap oversteer prone.
it'll be like driving a loaded slingshot being head by a sweaty finger.
have fun with that.
its all the one car now right?
the slashes aren't fuckin ornamental. Different cars, different parts, same chassis, as has been for the last 4 generations.
If I wanted to please people here I wouldn't have bought an MR2 :D Coz y'all hate them.
But Shan is right about the mexican fronts. Doesn't look so good. Popo wouldn't like it either.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
