found a dude that custom makes some sweet fabric for lining the roof of ze golf.
I'm thinking of getting either one of the kraken ones in the top left or the skull one on the bottom right.
yeh if he had a comby van
golf is a miniature combi van.
want something different from boring as shit plaid that all the other guys do. It's either an interesting fabric or black or someshit.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
