gdogzgtr
oh why would he wana help me stooge vic? lol..spose cops get paid poorly maybe
so would a straight through 3" with gutted cat and a cannon do it?
dont care how illegal it is i want it.
Alex get a vid of yours already man
yeh aight man ill grab one for ya, its fair loud just so you know, deffs not for a daily although billy does
What kind of headlights do you guys all have?
I've got those Phillips blue crystalvision or diamondvision or some shit. They look really blue, but aren't particularly bright lol. Looking for a change soon.
:D cant be THAT loud... yeah mostly use my car for weekends nowdays definately not daily
Cool, thanks Kris.
R-SPEC, are you selling your car?
if i get a decent offer why not
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
