love how people think their cars are the shiz just coz they have good wheel fitment when most of their body panels are smashed up with mismatched colours...
apparently thats "jdm" tight yo :huh:
more like cheapo spec... fix your car before you spend all your money on wheels
man cars looking good is sooo 99 autosalon sa'll about banged up panels and fitment thats were the love is at
wana borrow my hammer can damage ya own rear quarter say its drift damage :D
If I wanted to have 11ty billion kw I wouldnt be spending money on body parts. I would have jumped straight into the engine mods.
I also would have went for an r33.
I suggest you know the full story before you act like a tough guy and give it to people
then why not buy a NA 4 door and make it look nice on your p's if you wernt after power
saves the fuck around trying to get the exemption in the first place, then when your 21 can buy a turbo?
actaully its not 'jdm tyte yo' its called 'drift spec' fag
i still dont know why people take critisisim to heart on forums or about cars, people have different taste, so some people might like what you have done to your car while others will hate it as long as the owner is happy with it who cares what other people think. my car has shit fitment but i dont really care i prefer to get a carbon fibre rear wing blade instead :D
mmmm carbon wing blade ftw..... never regretted getting mine :D
drift spec is japanese bogan spec. seriously we see a banged up commo we think bogan
lol tyre barrier shaped hammers and shit
Hmm...
I have a dilemma...
Buy 33 gtst and whack 3071r or 32 gtr?
I'll put the gts4 up for sale later today $4.5k with 12 months rego.
Man, I miss real power!
haha at all the kunce getting cut as shit over funky's posts. if you cant take the heat, gtfo wasteland and put yo mothers' teats back in your collective mouths. know where you stand, and that others have a different opinion to your high strung ass.
srsly, my 12yo cousins are harder to troll than some people on here. also neg'ing all of funky's posts aint gonna get your point across, the dodgy bastard can probably just reset them
Looking at buying a daily in feb, wish I could have a gts4 as a daily!
33 gts4? why?
long hair no care. removing rep system in a week anyways.
Not specifically a gts4, just said that because grant is selling his, but really just an import. Hopefully a sil or skyline. See how much cash I have to spend in feb. My car is at the point where it's a pain in the ass to drive on the street and park places.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
