fkn weapon awesome value there is a 335i e93 (hardtop convetible) for 77k with 26ks on it in bendigo premium selection bmw i was looking at in but meh.. dont really wana tip 20k out of my pocket to upgrade
hmmm i know i could get one but not interested in convertible, i think im the same as you i could stretch my pocket out a bit more and get it but i think i might just wait a while.
IS300 only came in 6 speed auto, but has the 3.0 in it.
IS200 manual + auto, only 2.0 6cyl
Should get this one
http://www.carsales....=1011&keywords=
Black and dumped. :D
it has the optioned GPS too.
Edited by NguyenIMPROVED
Should get this one
sif that hasnt even got leather or sunroof :/
coulda sworn i seen one for sale a while ago with a 1/2jz cant remember which it was. would be a sweet luxo sleeper
335i are really fast when you flash the ecu.
Rode in one, I was blown away, 300rwkw with just a reflash.
Early model coupe are going for same money as E46 M3 now.
i f**king hate people
sitting in the car waiting for mum to get back, lady pulls up in a shiny new accord, parks alright gets out, trips and slams her hand on my bonnet/front right quarter WITH THE KEYS IN HER HAND AND DRAGS HERSELF UP.
WHAT THE f**k.
fkn women
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
