Thanks mate, I'll be getting my rental bond back soon, so it will be time to do some shopping ; )
How much would I be looking at for those bushes as mentioned?
PM this guy. Ask him for price of r33 front/rear camber bushes and castor bushes etc
http://www.nissansilvia.com/forums/index.php?showtopic=317763
http://www.nissansilvia.com/forums/index.php?showtopic=298461
Haha my Christmas pressies are being shipped off tomorrow, he won some items earlier in the week for me :)
Well alex, I'm trying lol manifold would have been great!!
Yer mirrors are on, should have a few new goodies next week! Then you must see my car!!!
cant wait to see your car in person agaib billy.... the roof spoiler the same as alex and mine?
also the ganadors are gonna finish it off sweeeet... the only problem i find with them is that you become a mirror snob. imho all skylines should have ganadors/craft square
Don't get the QFM A1RM pads either. Mine screech so bad i'm considering getting rid of them. There are much better options out there i'm sure.
Mine were fine, rarely screeched. can't remember them being to dusty either
Bendix Ultimates were aids, screeched more the the A1RM's, dusty as f**k, chewed the rotors and pretty sure they cost more than I paid for the A1RM's
Guy that bought my car has done some track days, not sure if he changed the pads first though
Yer I ordered the same as you guys but ive also got another one of my old roof spoiler so ill decide when it gets here and sell the other.
Ganadors do look good on and your right, you look at other 33's differently haha
Im not excited for my fog lights though, hopefully they look good!!
gl this time :P
thank you
hopefully no arrogant retarded impatient maroon magna drivers are around this time.
i swear every time i see a maroon magna im tempted to swerve into them, head on. kill em all
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
