If I want it to be 100%, I'll need to piss at least 10k on it.
I need to piss the dynamat off, previous owner had it covered in boot including 4wd and HICAS ecu... Stereo wiring to be binned, sound deadener removed, louder exhaust required, new wheels, 100k service, rip the hicas off, list goes on...
That shit you listed will take half a day to do.
Theres a reason why r32's are selling cheap and you have to be pretty silly to buy one and not expecting to work on it.
Go buy a Toyota Corolla if you dont want any hassles
Yeh Leigh, 5. I'll try make some cash on it...
Mx5 lol, would lOok hilarious driving that.
Eh, I'll work it out, if exemption gets knocked back, I'll cut my losses and sell it for what ever it gets and buy a landwhale. If it doesn't get knocked back, well. Fuuuu dead aircon
lol i dont want to spin all 4 wheels, easier to buy an RB20DE and swap it in.
i dont wanna go fast, i dont wanna track it( yet) happy as long as its a skyline
you're missing the point. Your gts4 has a 4wd drivetrain. Including all the heavy bits involved which, as noted, become useless because the na won't produce enough power to drag the heavy ass body around in 4wd and the extra weight and less power will mean a barina will probably win in a drag race.
Join the Rolla Club Mohsen!
AE86 for da sidz yo!
:laugh:
sudden infant death is all the rage these days with the muzteks maccas employees?
You missed the part where I'm a red p Plater that is not interested in dragging people. Rb20det is already slow as it is
think you missed the point where even Nissan went "shit this thing is slow as, alright, lets make it standard with a turbo and not have an N/A option." You seem to want to do what even Nissan didn't want to. Shiet bitch, you mad!
hence why the R33 GTS4 and R34 GT-4 had no turbo, cos the 2.5l n/a met their power to weight ratio requirement. GTS4 and GT-4's were meant to tow shit and be passenger taxi's you took to the snow. They weren't meant to be sports cars, they got the worst of all the models, small engines, heavy drivetrain power loss, heavy chassis/suspension etc. You pretty much buy one as a daily to tow shit around, or pull almost everything out of it and replace it with GTR guts to make a GTR sedan. No one in their right mind buys a standard GTS4 and thinks it's a great sports car.
turned the car on today and its knocking from the back of the motor.
just a slight knock but it changed with light revs. :/
turned car off straight away
clearly you cant tell 100% what is smashed without pulling it down, but how much am i up for if it's just a bearing?
and what the hell should i do if it's more :/
wrecker lucky dip? refresh? rebuild?
why would it be worth any more then what you bought it for lol, i tried the same thing when selling mine, for lols i put it up for 14k, ended up reducing it to 10, and getting 9.5k for it in the end
maybe chuck it up for 6.5, if no bites in a fortnight then gonna have to put it down, also depends on how desperately you want to sell it, took me about 1 month or so to sell mine.
if anything you paid too much for that car. cut losses and sell for what you bought it for a $100 less, at least that way some cheap dropkick will buy it, just like you did.
otherwise you'll end up with a car you can't drive that you can't sell, with no money to buy another.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
