15k might be a bit much for a 12 year old stock auto r34 sedan tho, regardless of condition. unless you're expecting to be lowballed.
I'm not really asking $15K for it anymore. Most of the lowballing initially was around the $12K mark, f*ck that! I had a decent offer of $13,500 as is from an interstate buyer (so I would've kept remaining rego, custom plates and wouldn't have put new tyres on it or got a RWC.) I kick myself now for not taking that.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
