hey grant but i just happened to look at hamishes pics and the white gtr looks just like yours...you should get some parts off it and do the 32 up ..its got all the parts you wanted to make a 350 rwkw .................and no air bag steering wheel
The white GTR was mine, my next door tried to talk me into buying it back.
My GTR has already got N1 turbos so kinda pointless on buying a wreck to pick the turbos.
or save the money, sell the car and buy something you wont hate again next week?
That is the plan but as you can see I get distracted easily...
Should I cancel the F/S ad and buy the wheels off Shan?
It'd look good even if I set it on fire.
masssive wheels on a gtr is pointless they arent made for the stance scene they are for the go fast scene
who brought it may be thay can do a deal as i know you basically gave it away the next day and do a transplant for all the good bits into another 33..maybed a sleeper
Thought about that but can't be arsed, I've thought about buying 33 GTR shell and transfer bits but not sure if I want the effort.
If I managed to sell my GTR, I'm likely to buy 33 gtst.
would need epic camber or flare up front
I know, maybe 3 degree or thereabouts? Also stretch tyres, 225/45 or 235/40?
There's a set of 18x10 +18/9 AVS Model T5 for sale (same size and offset as Niroj's).
So I've got to decide whether to go bit naughty or go completely bonkers... Will decide when I've done the first step.
It'd look better on 33 gtst?
yerh cos why ruin a gtr with camber n fitment an shit
it is getting pretty annoying reading posts all day about you hating your car....in other words, it's beyond annoying so shut the f**k up about it
thought i was the only one who thought it was kinda annoying, if you hate it so much sell it
  • Like 1
fkn cant remember mang...
the rear's are set so they are almost flat on WOT (so like 1 deg neg mebbe?)
it's just done with superpro bushes atm, but will have to go upper arms if i go any lower
Selling the GTR now, may put it up on ebay tomorrow.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
