And yeh Kris dont mind a bit of lag, once your out of first / hard launch all good anyways :P figured cams will help out a bit as well
get smaller turbo's while it's a stocker
if you blow it and build it for more power you can just sell the turbo's and buy new ones then... they have to come off anyway
SR20DE IN A C18DE s13
legal? easy? all good?
legal. not easy. no.
hell, besides the engine you need a completely different crossmember, gearbox, driveshaft, wiring, ecu, diff, power steering, alternator, waterpump, fuel pump, oil pump, intake manifold, exhaust manifold, etc.
which part of going from a 1980's cast iron block engine to a 1990's alloy engine did you think was gonna be easy?
can be done, but given your ghetto budget it's gonna cost you too much compared to the cost of the car.
LOL i know that. had a look at some tutorials, meh, too much work. shan wanna do it for me? ill shout you KFC
Then why did you post asking about it? Quit being a cock juggling thundercunt.
Also, not thanks, I'll make more doin my job in the same time it takes to do your engine swap than your car and new engine is worth. But I don't want you leaving empty handed, so here, I'll give you a new warn for being wacist.
my mate in sunshine's gettin rid of an N/A integra if you want. He's buying an R32 cos he just got off his p's, he'd probably straight swap yours but he wants a manual coupe.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
