Buying a new turbo :D Same one as I've got now but rebuilt, hi-flowed and steel internals. More for reliability's sake than power, but I should be able to get at least another 20kw out of it if I choose to.
Only $600, and my current CT20B should sell for $300 lol. So not a bad upgrade for ~$300
its a step up from when you are around animal killer.
there is good deals on cars at the moment they are selling so well so 25k should get you into a golf.
I've turned my back on my previous life man, I'm a part of the sea shepherd and PETA now
Where can I get an Exedy HD clutch for cheap? Everywhere is a rip off.
Btw, those hubcentric spacers I got (which a few people here suggested) I gave to workmate. Within a month he snapped a wheel stud haha...
Check the price on ebay... then head over to your closest Supercheap Auto/Autobarnz and they should be able to price beat ;)
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
