win!!!!!
haha love the plates FTW
Even if it is a vs v8, it's still nothing to write home about.
5.0L 'power' is gay with aids in the ass.
i had a blue vs 5.0 twin turbo come up to me the other day, didnt bother so he cracked it and punched it as hard as he could to show it had something
i was far from impressed most cars around 200kw would beat it easily
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
