As for the orange wheels, I wouldn't be using supercars and full body decaled drift cars to convince myself something will look good, because they won't look like that on your car
thruth.
this man speaks it.
Pat, your R32 is not a GT3... :laugh:
Go White or Bronze for a clean look.
If you want a tough look go Black.
lmao i couldnt see shit in the fog, saw leigh turn off, thought something was up so i followed him into a side street.. turns out he was going home haha
will bring a CB next time and damnnnn my car looked so shit compared to everyone else, now i know what all the r32/ 4 door hating is all about baha
U just need to know how to make it look good.
:D
Lol sorry about that Mohsen, I had like under 1/4 tank left (wasn't full) and needed to be back in my area, got my mate to try and wave people past but yeh cos I was at the front I knew someone would follow :P
Billy - Love your wheels and nuts :worship: oh and fitment, what can I say couldn't even get my finger under.
Alex - Car is looking mean those pipes top it off, get some matching rims though bro! and yeh 1 inch should be sweet I recon.
Mohsen - don't buy a older car will just be more trouble then its worth IMO, if you really do want to keep your 32 that much, save a bit buy a stock R31 or something and keep the 32 for DECA / track etc and put some nice track mods on it, then drive it when you get off Ps or when your bored some nights :thumbsup:
Oh any anyone got pics of the 34 GTR? didn't really get a good look but when it drove past those rims were sex what were they? was moving a little fast (TE37 special edition?)
After yesterday's cruise decided to do suspension instead f bigger power. How bad was my body roll Billy when You where behind me? If Hamish thought my car was scary that's saying something haha
Dude I was scared for you, I was following close but your car was all over the place!!
You need Coilovers and sway bars immediately!!!
Good work Kris :) About time you got onto that.
What coilovers are you thinking of getting?
Not sure, but it wont be crappy bc/g4/whatever other cheapies are out there lol
Hamish recommended the Greddy ones so ill look into them
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
