yerh its just easier since they are already white easier than getting normal gtst ones and having to repaint but yeh. better find out if the fit i cant imagine that they dont.
wheres funky im sure he will have a wealth of knowledge on the subject
my guess would be no, i remember when troy did a complete reshell of his 34r he used a 34 4door chassis that i think he had to lengthen. I dont recall, search for a thread by ylwgtr2 i think is the username
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
