ive been waiting on swaybars from the US for ages....
suppose thats what happens when you have them shipped and only pay $165 for a front and rear :P
sheeeet dude that's cheap! I got whiteline for 180 each..
good old sydneykid group buy...
overcharging for 1 part by $200+ over retail for years in his super discounted group buy
Bought the same parts at my local repco (and no I don't know anyone there, and never bargained with them) and saved at least $500 over what SK was charging
I now want to hit the ex across the head with a shovel.. Gets engaged and then calls my sister complaining about how tight the other dudes being.... Why call my sister for? Of all people.....
Didn't he just f**k off with people's money for ages too?
cos she has bigger nuts that you
R33 GTR seats don't hold you in for shit. I'm getting a bride when I get all my suspension goodies
That's cause you're a runt :D
They hold my tubby ass perfectly! But then i have the seat upright so gravity works!
no idea, I was long gone before that ever happened
What clutch are you getting? used to be able to get a nismo clutch kit including lightened flywheel for like $1200 brand new from nengun
Farkk.. It's costing me $950 for my new clutch kit. Then another $500 for a lightened flywheel. I can see this trip to the mechanics going well over $3000
why are you going a lightened flywheel?
they get the revs up faster, but they also drop faster in between gears as a result.
what are you intending on using the car for?
My mechanic was insistent that it would work better with the clutch I'm getting. So I just told him to go for it.
I was going to get one anyway. Less drivetrain loss :)
Car is predominantly a daily, but used for hill climbs and track days too.
Trying to get a good balance between looks, performance and practicality/reliability.
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
