you should see this black one that comes to my work... its slammed on eurolines.... looks hawt
Still wouldn't own one unless I had to for some reason....like if my job description said 'must drive a square box, with no logical reason for looking so bad', then I would.
lol. buyer starting to stuff around
now wants to pay cash after making sure car matches the description.
no worries, described it accurately
BUT IM NOT DRIVING TO f**kING GEELONG FOR HIM TO POTENTIALLY SAY NO
shit news with Japan :( i think we should organize a cruise and raise some money for them.
Or just buy heaps more JDM parts to boost their economy ;) That sounds like a better plan.
Managed to get in touch with my uncle in Japan last night. He says he's okay and got minimal damage. So relieved.
haha, now theres an idea. might buy even more things if our dollar gets stronger to there yen.
http://cgi.ebay.com.au/NISSAN-SKYLINE-GTR-R34-V-SPEC-700HP-NISMO-R33-R32-/120694617215?pt=AU_Cars&hash=item1c19f5b47f
this guy is a knob
why would u start it at $1
why not start it at the minimum you would take for it to stop wasting time
its currently at 33k
i would laugh if that was highest bid, cop that
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
