saw a ferrari driving in the city with arab numbers plates on the front and back O_o
Too good for vicroads plates lol. I guess the fine for not displaying plates is toilet paper
you can drive on international plates if you have a permit.
At least there was no similar car nissan aus supplied to skylines etc
what do you call 200sx's and 300zx's?
manufacturers like toyota/nissan are more protective of their family and entry level sedans (maxima/tiida or camry/corolla) which they sell by the hundreds. No import quantity will ever scratch that. Keep in mind that each RAW can only bring a total of 100 cars in a year per category. They make 10 times that in a week.
They only get shitty when you start bringing in vans as campervans, or 15 year old imports that are as equally feature rich as their new cars etc and start cutting into their markets in a major way.
Just looked at 300rwkw R33 gtst (turbo is Blitz K5-660) goes pretty hard, in coming days I'll contact the mob who built it as the motor is forged (seen the receipts).
Noticed couple of things, there's a sensor on inlet pipe (next to BOV which is blocked) and pink label afm (it's R33 S2 and running on Power FC), hence my curiousity.
Wasn't a d-jetro PFC was it? Unplug AFM and she if she starts?
No d-jetro for ECR33 though, but after work, I'm off to Amberley Autos and talk more about all this.
Btw, you got address for Trents new shop? PM me if you have to.
so there are now unmarked revenue raisers cops on unmarked red motorbikes wearing black leathers that hide on the side of the road and pin you for driving offenses....
using hand held device - 3 points - $239
fml
Thanks for the reasonable response.my husband and i love the car, we have a car but need one more cos we work at different area of the city and its kinda far from our home, i am very happy with the present condition of the car as you stated and we promise to take good care of the car as i knew no doubt about it. we have just relocate to beijing china, and we want the car to be ship to china so we will not be able to come over and inspect the car. so we will like to see more pictures of the car. as for the mode of payment we will be paying you via bank transfer, and also i have registered with a shipping company which would come for the pick up after payment pls get back to me asap Regards
ummm.... she asks if car is still available. i get this. lol
