The 33 I liked is in fact a 1996 (Compliance plate said '98, green plate pre-SEVS btw), should I steer away from it or not even though it isn't under finance or stolen or write-off register?
imo, if you like the car just get it every car will have small problems from the 90s mine needed new suspension and tyres as well as needing to repair the front lip but still loved the car when i saw it so i got it! :thumbsup:
tl;dr Shit can be fixed :D
Nah, that isn't what I meant, I were saying the car was complied as '98 model when the actual chassis is in fact a '96 model, not sure if I can live with it.
buy mine man.... 30k
Since you don't have the Professors on, no thanks.
Haven't had the chance to look at grey 33 in woop woop, may do that this weekend.
harden the fuck up princess. Was probably a typo in the CPA registry that sent out plates.
If the car has been registered, and has a history in one of the national registration systems, no one gives a shit about the plates. The only thing that's used for is the initial rego.
Grant come to shep on Saturday and tell the guy to meet you at DECA rolleyes.gif
Shep is closer for him.
Just got a message from the seller, he doesn't seem that keen but told him I'll be there...
Shan, is it pretty common with pre-SEVS cars?
Just want to be sure before I go stupid and buy it.
It's not common, but it's not surprising. a car I bought didn't even have a plate. which was fun, ran around for a month trying to get it from canberra and it turned out I didn't even need it to reg the car.
just make sure the VIN on the plate of the car matches the VIN on the manufacturer plate, and then run that VIN through FAST to make sure the specs of the car match up.
eg: 6U9000ECR33123456 = ECR33-123456 = RB25 R33 GTS25t
Thanks for that but, is error on import approval or mistake by Canberra put it on wrong year pretty common during pre-SEVS days?
The VIN on said 33 isn't 6U900xxxx it's 6T91 thingy hence my curiousity, what sparked it when I ran it thru Vicroads check and FAST (VR listed it as '98 whereas on FAST, it's 96).
6U900xxxx is new SEVS system, under CPA it was some weird shit.
Errors happen, check that the VIN numbers match up properly. No one gives a fuck about the year.
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
