So im thinking of taking the mrs out for dinner for her b'day at the start of april wheres a really nice place to go for dinner. I'm sure you all can think of a place :) budget is like $200 inc booze i guess. I live inner east if that helps
BYO, but don't get caught.
:rofl:
$200 all day or $200 per head?
If you can stretch to $200ph i'd say go to bistro vue
or if you can stretch it to $280 and make it a tuesday, go to attica for the "Tuesday Night Chef's Table"
it's a 5 course tasting menu, with wine match ($90 p/h without wine)
it's the night that they try all the new dishes out... you HAVE to have an open mind tho cause it could be ANYTHING
Chinese food catered for whities :laugh:
never.... chicken feet ftmfw (fuck the westernised shite)
The plot doesn't thicken. I've known her for years. She has a boyfriend, and even if she didn't, it's strictly business. Pay the rent on time and I won't throw you out in the street :)
Can she pay with sexual favours?
Nope
:laugh::laugh:
not sure of cost but i rkn like eureka tower would be impressive
never.... chicken feet ftmfw (f**k the westernised shite)
:laugh:
yeh the view would be amazing and if you got a clear night all romantic an shit, well geez i rkn even id give ya a crack andrew :P
bnahaha
hahahhaa soooo alex .... what are you doing later? wanna catch up for uhhhh dinner?
So Bromantic you two :laugh:
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
