Yeah well.. I'm having a protein shake.. >_< Fail.
if you wanna be all "fit" & "sexy" and post pictures of yourself posing on facebook etc, then you have to put up with filty things in your mouth like protein shakes and semen
So im thinking of taking the mrs out for dinner for her b'day at the start of april wheres a really nice place to go for dinner. I'm sure you all can think of a place :) budget is like $200 inc booze i guess. I live inner east if that helps
City Grill Room for an awesome steak.
just bought tint for the golf. 3M, precut, 25% VLT. $100 delivered. Sooo fuckin good to have a car where you can just contact a distributor/manufacturer and not have to custom order shit.
Hello Nissan, yeah I need a coil harness... what? the plug is different for the year? OK, what? Have to custom order from japan? What about the other one? Oh custom order that too? What? If I splice a CA18 plug into an RB30 harness it'll work? Fuck off.
<hang up>
Ohio Nissan Japan! What? Nuclear meltdown? Have to custom order? Fuck obu.
<ring chinese import co>
Hi, I need a harness. Yes, I'll bring the lube in exchange for your shitty knockoff with plugs that are more brittle than the 20 year version I'm replacing.
$200 all day or $200 per head?
If you can stretch to $200ph i'd say go to bistro vue
or if you can stretch it to $280 and make it a tuesday, go to attica for the "Tuesday Night Chef's Table"
it's a 5 course tasting menu, with wine match ($90 p/h without wine)
it's the night that they try all the new dishes out... you HAVE to have an open mind tho cause it could be ANYTHING
never.... chicken feet ftmfw (fuck the westernised shite)
oo that attica one sounds good. Cheers for the recommendation.
yeh i was fkn around man i'm huge on service happy to pay premium provided the service matches the price.
my tag watch cost a bit, there level of service was top notch and after sales complimentary pen VIP invites etc makes me happy to buy there again.
Like a Boss
<hang up>
25% weak dude weak. Minimum 18% for street cred. Serious business
street cred can suck my dick. 25% is best balance of visibility and solar evergy rejection.
My biased opinion > Science + Maths > Street Cred > you
haha 18% is perfectly fine. Im rockin it on my r32 and you know how shit-house the headlights are on them
5% is when you start shittin brix at night as you cant see shit
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
